Permalac Black Acrylic Paste Additive
This black acrylic paste additive can be used to yield a solid black finish if you wish to tint the Permalac yourself. To obtain an opaque black effect, add approximately 1 oz of black paste for every 8 fluid ounces of Permalac Original or NT.
1 Quart Can
