| SAVE THE WATER, PROTECT YOUR VEHICLE! |
| Sahara Wash and Detail is the only safe solution to washing and detailing your vehicle as an express polish or after care product. This does not replace Glare Professional polish. This is a beautiful after care product when your vehicle gets very dirty and you want to clean and maintain the original deep beyond wet look shine you received using the Glare Professional Polish. Sahara Wash and Detail is a safe and effective wash and detail product rolled into one. This product is the perfect solution when water supply is limited. Do not confuse this product with Glare Rapid Action which has a 6 months lasting protection, and is not a wash. Safe on all exterior materials. The most revolutionary product of this kind on the market. Easy to use on all cars. Clear coat safe and recommended . This is the best spray polish you can buy. Great for use on motorcycles, glass, and polycarbonate as well. BEYOND 22ND CENTURY TECHNOLOGY! 16 oz bottle with spray nozzle |
