GLARE STRAND LOCK - 12OZ W/SPRAYER
Contains Strandplexin which locks in protection in carpets, fabric, suede, vinyl and leather. Protects and shields from the elements including UV rays. Withstands spills like soda, coffee, dirt, grease, juice etc. Apply to clean, dry area. Spray evenly onto area to be protected and allow to dry.
