Quick view Caswell sku: RECT30 RECTIFIER - 30 AMP MSRP: Now: $349.00 Add to Cart Compare Quick view Caswell sku: HCS-3602 RECTIFIER 0-30A, 0-32V MSRP: Now: $499.00 Add to Cart Compare Quick view Aldonex sku: RECT10012110 Rectifier 100 Amp - 12 Volt DC. 110 volt. 1 phase AC. Digital amp and voltmeter 100 Amp MSRP: Now: $5,205.00 Add to Cart Compare Quick view Aldonex sku: RECT1006110 Rectifier 100 Amp - 6 Volt DC.110 volt. 1 phase AC 100 Amp MSRP: Now: $4,408.00 Add to Cart Compare Quick view Aldonex sku: RECT1006220 Rectifier 100 Amp - 6 Volt DC.220 volt. 1 phase AC 100 Amp MSRP: Now: $4,408.00 Add to Cart Compare Quick view Aldonex sku: RECT1009110 Rectifier 100 Amp - 9 Volt DC. 110 volt. 1 phase AC 100 Amp MSRP: Now: $4,962.00 Add to Cart Compare Quick view Aldonex sku: RECT1009220 Rectifier 100 Amp - 9 Volt DC. 220 volt. 1 phase AC 100 Amp MSRP: Now: $4,962.00 Add to Cart Compare Quick view Caswell sku: RCBRT REPROCHROME BRIGHTENER MSRP: Now: $12.09 Add to Cart Compare Quick view Caswell sku: RC1G REPROCHROME PLATING SOLUTION MSRP: Now: $107.79 Add to Cart Compare Quick view Caswell sku: RC3 REPROCHROME Upgrade Plating Kit - 4.5 Gal MSRP: Now: $446.59 Add to Cart Compare Quick view Caswell sku: RCT1 REPROCHROME® Triple Chrome Plating Kit - 1.5 Gal MSRP: Now: $845.89 Add to Cart Compare Quick view Caswell sku: RCT2 REPROCHROME® Triple Chrome Plating Kit - 3 Gal MSRP: Now: $1,136.29 Add to Cart Compare Quick view Caswell sku: RCT3 REPROCHROME® Triple Chrome Plating Kit - 4.5 Gal MSRP: Now: $1,475.09 Add to Cart Compare Quick view Caswell sku: RC1 REPROCHROME® Upgrade Plating Kit - 1.5 Gal MSRP: Now: $216.69 Add to Cart Compare Quick view Caswell sku: RC2 REPROCHROME® Upgrade Plating Kit - 3 Gal MSRP: Now: $325.59 Add to Cart Compare Quick view RECTIFIER - 30 AMP 30 Amp Plater This heavy duty unit will plate larger items. Will nickel & copper plate items up to 3 sq ft in area. Not suitable for anodizing, due to it's lack of constant current mode. 0 - 20 Volts d.c. 0 - 30 Amps d.c. Continuously variable... MSRP: Now: $349.00 Add to Cart Compare Quick view RECTIFIER 0-30A, 0-32V 30 Amp, 32V Constant Current Rectifier Best for anodizing. 32V allows for increased current densities and shorter anodize times Please note, during the current supply chain crisis, we may substitute this item for a similar item that WILL perform as well... MSRP: Now: $499.00 Add to Cart Compare Quick view Rectifier 100 Amp - 12 Volt DC. 110 volt. 1 phase AC. Digital amp and voltmeter 100 Amp Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement... MSRP: Now: $5,205.00 Add to Cart Compare Quick view Rectifier 100 Amp - 6 Volt DC.110 volt. 1 phase AC 100 Amp Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement... MSRP: Now: $4,408.00 Add to Cart Compare Quick view Rectifier 100 Amp - 6 Volt DC.220 volt. 1 phase AC 100 Amp Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement... MSRP: Now: $4,408.00 Add to Cart Compare Quick view Rectifier 100 Amp - 9 Volt DC. 110 volt. 1 phase AC 100 Amp Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement... MSRP: Now: $4,962.00 Add to Cart Compare Quick view Rectifier 100 Amp - 9 Volt DC. 220 volt. 1 phase AC 100 Amp Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement... MSRP: Now: $4,962.00 Add to Cart Compare Quick view REPROCHROME BRIGHTENER Add to Reprochrome solution at the rate of 0.4 fl oz per gallon to get a bright plate. MSRP: Now: $12.09 Add to Cart Compare Quick view REPROCHROME PLATING SOLUTION Use to replenish or add to a Reprochrome Plating Kit MSRP: Now: $107.79 Add to Cart Compare Quick view REPROCHROME Upgrade Plating Kit - 4.5 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Buy This Kit If You Already Have a Nickel Plating Kit, or wish to convert from Triple Chrome to Reprochrome® Introducing REPROCHROME®, a unique Cobalt/Tungsten... MSRP: Now: $446.59 Add to Cart Compare Quick view REPROCHROME® Triple Chrome Plating Kit - 1.5 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Introducing REPROCHROME®, a unique Cobalt/Tungsten alloy that contains no chrome, nickel or toxic materials. REPROCHROME® duplicates a chrome plate in color,... MSRP: Now: $845.89 Add to Cart Compare Quick view REPROCHROME® Triple Chrome Plating Kit - 3 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Introducing REPROCHROME®, a unique Cobalt/Tungsten alloy that contains no chrome, nickel or toxic materials. REPROCHROME® duplicates a chrome plate in color,... MSRP: Now: $1,136.29 Add to Cart Compare Quick view REPROCHROME® Triple Chrome Plating Kit - 4.5 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Introducing REPROCHROME®, a unique Cobalt/Tungsten alloy that contains no chrome, nickel or toxic materials. REPROCHROME® duplicates a chrome plate in color,... MSRP: Now: $1,475.09 Add to Cart Compare Quick view REPROCHROME® Upgrade Plating Kit - 1.5 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Buy This Kit If You Already Have a Nickel Plating Kit, or wish to convert from Triple Chrome to Reprochrome® Introducing REPROCHROME®, a unique Cobalt/Tungsten... MSRP: Now: $216.69 Add to Cart Compare Quick view REPROCHROME® Upgrade Plating Kit - 3 Gal The Look and Strength Of Real Chrome Without Environmental Issues or High Current Requirements Buy This Kit If You Already Have a Nickel Plating Kit, or wish to convert from Triple Chrome to Reprochrome® Introducing REPROCHROME®, a unique Cobalt/Tungsten... MSRP: Now: $325.59 Add to Cart Compare Previous 16 17 18 19 20 21 22 23 24 25 26 Next Previous 16 17 18 19 20 21 22 23 24 25 26 Next Compare Selected × OK
