NOTCHEAD POLISHING GRIP
Tired of your bolts shooting across your shop? Tired of your bolts getting too hot to hang on to while polishing?
This award-winning Polishing Grip provides a solid, secure grip for polishing or grinding.
The NotcHead™ Polishing Grip will grip almost any type of bolt or screw, from sizes #4 through #10 and 1/4" through 3/8".
The NotcHead Polishing Grip is proven to increase safety, efficiency and productivity, as well as decrease burnt fingertips and flying bolts. The all-aluminum design easily cinches down and grips the bolt for you, without damaging the threads.
Never handle a hot bolt again! After you're finished polishing, just loosen the collet ring on the Polishing Grip and drop the bolt right out.
This hand-held NotcHead Polishing Grip™ is designed to quickly and easily grip almost any type of screw or bolt and provide a secure handle while you polish or grind. It is all aluminum, so it won't damage threads, and has a hard anodized coating for extra durability.
The easy to use chuck design and the two included collets fit bolt sizes #4 - #10 and 1/4" - 3/8".
When people are in a hurry or not properly equipped, very often, safety takes a back seat. The NotcHead Polishing Grip™ is proven to increase safety, efficiency and productivity, as well as decrease burnt fingertips and flying bolts.
After the polishing is completed, you just loosen the chuck and drop the hot bolt out, without needing to touch it.
totally worth it!!!
Saves time, wont hurt threads, eliminates damaged parts and redos. It actuall helps me get the job done faster which will pay for itself.
Save your knuckles
Price is a bit steep but when I am working on old outboards with brass hardware this is just the ticket to keep the parts from getting ruined (vice-grips mar surfaces) and flying around the shop.
