Aluminum Oxide Sanding Disk 2" - 100 Grit
Aluminum Oxide Sanding Disks
- These novel aluminum oxide sanding disks quickly lock onto the sanding pad with a simple quarter turn.
- Long life, rugged construction gives rapid surface preparation in smaller areas.
