Rubber Sanding Pad and 1/4" Arbor, 2" Circumference
For use with Aluminum Oxide Sanding Disks.
- These novel aluminum oxide sanding disks quickly lock onto the sanding pad with a simple quarter turn.
- Long life, rugged construction gives rapid surface preparation in smaller areas.
