ZINCATE CONCENTRATE - 1 LITER
You Can't Plate Aluminum Without Zincate Pre-Treatment For Aluminum
Using CASWELL Zincate Solution, aluminum can be pre-treated, and then plated in one of our plating kits. The problem is that aluminum forms an oxide layer the minute it is exposed to air. This presents a problem when plating aluminum, as the oxide layer prevents the plate from sticking. By using the Zincate process as a pre-plate dip, we chemically remove the oxide layer and at the same time, apply a layer of zinc. The zinc protects the aluminum until it is ready to be plated. As the part is lowered into the plating tank, the zinc is etched away by the plating solution and plating proceeds onto a clinically clean surface.
The process:
- Thoroughly degrease the part in either CASWELL SP Degreaser or a detergent based cleaner.
- Bead blast the part to remove all heavy oxides and contaminants (optional)
- Buff & polish the part to the required shine.
- Make up the zincate solution by adding 1 liter of concentrate to 3 liters of distilled water.
- Heat the solution to 75°F. Immerse the solution for 15 sec. to 2 minutes. Immersion time will depend on the alloy, zincate condition and temperature.
- If the alloy reacts violently with the solution, then shorten the time immersed. If no reaction is visible, then immersion times can be extended.
A uniform gray appearance is usually a
sign of a properly zincated surface, however there are
cases where a dark, slightly streaked surface is acceptable.
As the zincate solution is depleted, there will be a
noticeable increase in the gassing. You can replenish
the solution by adding about 10% of the Zincate Concentrate,
or simply make up a new batch.
Rinse the part and prepare for plating. You can plate a zincated part directly with Nickel, but this will eventually contaminate the nickel bath with zinc. We recommend plating first with Flash Copper, then Nickel.
Hazardous Shipping Info
GHS Info
SDS
4 Reviews Hide Reviews Show Reviews
Zincate ofe Aluminum
Must do longer on time and at least 3times on parts to get the copper flash to stay on, be aggressive as you'll be redoing the parts
great stuff
Worked really well and I am very happy with it.
Exactly what you need to plate on aluminum!
I need to plate an aluminum car part and this helped me get the job done! Thank you Caswell!
Absolutly worth it!
The product came out GREAT! I used this to pretreat aluminum then flash coppered came out great! I took care while cleaning the part before and after...thanks to the reccomendations made by Craige @ Caswell. This company really stands behind their products. I was really worried that it was going to be time consuming to start plating projects. But, it has been quick easy with all the clear instruction I've been given.
