ZINC BRIGHTENER ADDITIVE
For use with Caswell Zinc Plating Process
Add 1/2 teaspoons per 1.5 gal of plating solution.
When plate becomes dull, add another 1/2 teaspoon.
***Do Not Add Entire Contents. ***
Use Sparingly.
SDS
Kits may contain more SDS than listed here. Contact us for details
