These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
7 Reviews Hide Reviews Show Reviews
Great color.
Very vibrant color. Higly recommended.
Awesome Violet Color
Good dye uptake. I left my parts in the dye at 140° for the maximum time with a oxide layer of .7 mil, final color was pretty close to what is shown. Surface finish plays a role in the final color also. Overall, I really like this color. It looks great.
Amazing
Just a fantastic purple/violet. Amazing saturation. It takes very fast at 140 degrees, but depending on the time it can go from a neon color to deep and rich. My favorite color so far.
Thanks for the prompt service
Fast shipping!! Thank you so much!!
alright
Turned out a little darker for me than what's shown, but great color.
Fantastic dye
I don't know if it's just the particular bottle I got or not, but this dye is fantastic. I don't have to leave my parts in very long at all for it to get the deepest most vibrant purples ever! I mean SECONDS. Not minutes. 45 seconds in this dye gives you a great purple.
Good dye
This dye absorbs well, and with all of caswell dyes has the ability to give lighter shades by soaking for shorter times. I love it!
