Preval vFan Portable Airbrush System
The vFan Portable Airbrush is an all-in-one touch-up system for precision painting, surface prep, touch-ups and curing – anywhere and anytime.
Our siphon-fed, dual-action stainless steel and brass vFan airbrush delivers professional results with a silent pressurized can compressor that fits in your pocket.
Our award-winning vFan Airbrush is a portable painting workhorse that sprays from a 1/16" detailed line to a 3" fan with total consistency and almost no overspray.
As a 'hybrid' airbrush system, the vFan Airbrush with most electric compressors.
The vFan sprays:
Every Preval vFan Airbrush System kit includes:
