Our new Brush Plating power and lead kit allows you to plate anywhere, anytime.
Simply plug the USB transformer into a battery power pack, phone charger, computer or most other USB compatible power supplies and then dial in the voltage required. It will accept Mini-USB, USB-B or USB-C inputs.
The unit has positive and negative output terminals to attach the included wand lead and cathode lead.
It will output a maximum of 30 volts and 2 amps. Voltage is fully adjustable to 30V. The amperage dial will set the maximum amperage that it will draw.
It can be used for all our brush plating solutions and could also be used to tank plate small items.
It includes:
- Adjustable USB Power Supply
- Red Lead With Banana Plug
- Black Lead With Alligator Clip
- Stainless Wand (others can be purchased here)
- Brush Plating Bandage
Watch the Video to see it in action.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
Videos Hide Videos Show Videos
