These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
4 Reviews Hide Reviews Show Reviews
nice light blue
Came out a very nice light blue,very nice
Excellent, very easy to use and beautiful uniform color.
I am a first time user and very satisfied with this product. The result is excellent, it's very easy to use and the color is beautifully uniform. Great.
bright
Color came out really good just as shown
Caswell Turquoise Dye
Nice dye, but a bit hard to adjust shades...got best result with 12 minutes, but 3 minutes is nearly the same shade.
