TURBO SONIC STEEL & STAINLESS CLEANER
Concentrated Steel & Gun Parts Cleaning Solution
- Scientifically formulated for steel and stainless steel parts
- Removes oil, dirt, carbon buildup and powder residue
- Deep cleans gun parts such as barrels, cylinders, slides and bolts
- Ideal for steel items such as dies and mould blocks
- Designed for use in the Lyman Turbo Sonic Ultrasonic cleaner
Mixing:
Light Duty: 1/2oz to 20oz water
Heavy Duty: 1oz to 20oz water
Tap water can be used, but for best results, use distilled water.
4 fl oz bottle.
Works pretty good.
If the parts are overly gunked up, this will clean them nicely. If they are took clogged you will need to break down the large amounts and then sonic clean it.
