Mack Brush Sword Striper
America's No.1 Automotive Touch-Up Brush
Used by all leading Body Shops for Paint Touch-Up and Pinstriping
Series 20
Finest Quality Squirrel Hair Stripers Made
- Lacquer and Enamel Resistant
- The Sword Style is the Best for All-Around Work
- Excellent for Auto Body Touch-up and Pinstriping
- Dark Green Thread Ferrule
- Length of Hair: 2 inches
- Available In 7/32" (Size 00)
