Hang parts for powder coating or painting with our swivel hook.
Strong, double ball bearing construction allows you to easily turn the parts to paint the other sides.
Our swivel hooks have a 300lb load capacity, great for hanging wheels.
Bottom V loop is 1.875" diameter and 1.745" high.
Total height of hook is 5"
Sturdy
Had been using hangers, but this hook makes all the difference. Coating is a breeze now.
Like
Nice piece
