Surface Preparation Quick Change Abrasive Disks
- Ideal for paint and light rust removal
- Uses the same sanding pad and arbor as the Aluminum Oxide Sanding Disks
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
