Non-Skid Fabric Coating. Stop rugs from slipping on floor surfaces.
- Durable Rubber Formula - Machine Washable. Stays Flexible
- Safety - Stops Skidding. Won't shift like other non-skid products
- Versatile - Properly applied to fabric first, stops skidding on all types of floor surfaces: wood, ceramic, concrete....
- Convenient - Easy to apply.
- Clear color.
- 11.5 oz can
