Plating the lead came on stained glass objects has historically been a tremendous problem for manufacturers of these products. Lead oxidizes extremely quickly after cleaning, and this prevents optimum adhesion of any plating. Conventional plating shops use cyanides to optimize adhesion and other unpleasant chemicals to remove the oxides.
The new CASWELL SUNCATCHER KIT incorporates the use of two new products
These new systems ensure that a successful primer is applied to 60/40 solder joints, as well as whatever came system is used, whether it be lead, brass or copper foil. After Flash Copper™ is applied, the part can be 'antiqued' using our antiquing solutions or plated with Copy Chrome™. Copy Chrome™ can then be plated with Gold or Silver using Plug N' Plate™ kits (not included)
The procedure:
- Thoroughly buff and polish the came to a shine, using the die grinder and white buffing compound. Degrease in SP Degreaser.
- Place article in dishwasher and run the cycle as for glassware.
- Dip article in PICKLE #4 solution for 2-3 minutes.
- Rinse in fresh water.
- Plate for 15 minutes with Flash Copper™.
- At this point, the copper may be antiqued, see our Antiquing Solutions such as Tiffany Green etc.
- Plate with Copy Chrome™ for 15 minutes.
- Lightly buff and/or polish using the white compound and a die grinder or buffing machine.
- If required, plate with Plug N' Plate™, Fast Gold or Silver. These kits should be ordered separately.
3 Gallon Starter Kit
- 1 x 3 Gal Flash Copper™/Copy Chrome™ Combo Kit
- 1 x 2lb Pickle #4 (Makes 4 Gal)
- 1 x 30 amp Rectifier
- 1 x 2" Shank Mounted Buffing Wheel
- 1 x large White Buffing Compound
- Free Technical Support
Power Supply Not Included.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
