PAINT Pinstriping with the STRIPER® enables you to match and repair just about any pinstripe job or to complete paint pinstriping jobs economically with superior results!
Our tape works as a stencil: you simply apply the stencil...paint over it...and peel it off.
It leaves the cleanest, sharpest line. Nothing even comes close. No fuzzy edges and no edge build-up because the stencil material is so thin. It is also versatile; you can make bends, points, corners and do two-tone pinstriping with it.
