Stainless Steel Polishing Kit
Kit Includes:
- 1 x Large Black Compound
- 1 x Large Green Compound
- 1 x Large White Compound
- 1 x 8oz Blue Begone Liquid Polish
- 1 x 4" Sisal Wheel
- 2 x 4" Spiral Sewn Cotton Wheels
- 2 x 4" Loose Cotton Wheels
- 1 x Arbor Adapter
- 1 x Medium Bullet Felt Bob
- 1 x 2.5" Mushroom Buff
- Instructions
This kit has been specially designed for polishing stainless steel trim and other stainless parts using an electric drill or similar chuck tool.
The sisal wheel and black compound are used for scratch removal. The green compound is then used to polish the metal, followed by the white compound and finally the Blue Begone liquid polish if desired.
Loose buffs are designed to compact into tight spaces for easy polishing.
The mushroom buff and felt bob are used to get into small areas where the buffing wheels will not go.
4 Reviews Hide Reviews Show Reviews
effective
No previous experience polishing like this. I used the wheels mounted on my drill press to polish a knife blade, after sandpaper grits up to 2000. Still fine visible scratches after the white, but the liquid polish applied using buffing wheel smoothed it out to mirror finish. Tip: Buying additional arbors will make the process more convenient, but are not required.
This is a great kit.
Using this kit in restoration of the stainless trim on a 1945 Plymouth. I especially like the chrome polish (green liquid) that came with the kit - it is AMAZING! Better than ANY polish I have tried. Nice kit at a good value. Delivery was super fast & ordering online was easy. Thanks Craswell, glad I found you!
Excellent product
Used this kit to Polish the exhaust muffler on my car. It completely removed the few rust spots & cleaned, polished the muffler surface extremely well. Reflection off the muffler surface is amazing. Kit has has everything you could need and can be used many times. I would definitely recommend this product.
Good
Would appreciate more instructions on the proper use of these products. Products seem to do a fine job.
