STAINLESS BUFFING COMPOUND LARGE
Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
SDS
6 Reviews Hide Reviews Show Reviews
Quick shiner
After initial use of the black compound on a sisal wheel, I've been using this green compound with a spiral sewn cotton wheel to quickly produce a good shine on the stainless railing I am fabricating for my deck. It does a great job which needs little effort to finish off with the white compound and I'm very happy with the result.
nice
fast shipping excellent great doing business with you
Quality compound
Nice even consistancy! I've used other brands and have had inconsistant chunks of abrasive. Not the case with this stuff.
GREAT STUFF
BRINGS OUT THE STAINLESS TO A GREAT LUSTER!!
as described
Fast and easy shipping
good stuff
Bought this in Jumbo size. Works great.
