| Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
SDS
9 Reviews Hide Reviews Show Reviews
performs as expected
As advertised
Product fine, but packaging poor
Works well on Aluminum too!
I use this to cut the lines and imperfections from the cast aluminum cases I use.
I highly recommend this company
Very satisfied. Fast shipping.
Just what I needed!
Though these large buffing bars are usually broken on arrival (this one was too), I'm very happy with the quality and performance of the product. The price was very competitive and Caswell is always a pleasure to work with. This bad boy will last me for a long time but, when I need more, I'll be buying it here too. Thanks for doing what you do best! Leanna ~ The CudaChick Owner/Operator http://PhoenixSpecialtyCoatings.com
Great compound...
I've been doing a lot of stainless polishing lately and this compound is great. I added it to my order of Black Compound to save on shipping because I knew I'd eventually need it.
pleased.........
polishes out stainless to a great shine, use black compound prior to this one.....
Good stuff
A nice compound that gives good colour and shine to stainless. I am finding that less is more with this and I keep the wheel very lightly loaded for a good finish.
