Stainless Steel Blackening Kit
Stainless Steel Blackener
is an acidic liquid concentrate used full strength or diluted with up to 3 parts water to blacken stainless steel at room temperature. This kit is not for steel; use our Black Oxide Kit for steel and iron parts.
Recommended for color coding parts and blackening engravings on stainless steels. Produces a pleasing dark gray/black finish. Seal with Caswell Sealer.
Caswell Sealer is a clear, water based acrylic sealer that protects and seals the blackened finish. Leaves a hard, clear, glossy finish. Does not add any dimensionality to parts.
Kit Contents:
1 Gallon | 2 Gallon | 3 Gallon | 5 Gallon |
Hazardous Shipping Info
GHS Info
SDS
