Stainless Steel Blackener Gel Kit
Easily spot blacken stainless steel. Simply apply the gel where you want the blackening to occur. The gel keeps the blackener in place. Leave it on the part for 1-3 minutes and rinse off. Seal with Caswell Sealer for a dry finish.
Stainless Steel Gel Kit Includes:
- 4 fl oz Stainless Steel Concentrate Gel (covers approx 2 sq ft)
- 4 fl oz Caswell Sealer
- Disposable Vinyl Gloves
Hazardous Shipping Info
GHS Info
SDS
11 Reviews Hide Reviews Show Reviews
Fantastic on every level.
This product is absolutely thorough and extremely fast at blackening stainless steel. I've tried other stainless steel blackeners and they simply cannot compare to the ease of use and the quickness of results. Will buy again. Definitely recommend.
Works Awesome!
Have a Sig 226, it has the nitride black finish over a stainless slide. Turned the nicks in the finish (exposed stainless sliver) back to black. Worked in about 2 seconds. I would highly recommend this product.
Good product
This does exactly what it's supposed to do. It'll turn stainless steel a rich deep black color. Almost like a flat black paint. Be advised: it'll react differently with different grades of stainless. High carbon steel takes a full 2+ minutes to turn. Stainless with low carbon will turn quickly. When you see it starting to turn a reddish brown color you waited too long. Rinse and repeat except this time don't leave it on so long. That aside, great product. I used it to blacken 2 stainless rifle barrels and 4 muzzle brakes.
great find
wanted to darken a small stainless item and this little gem did the trick. very satisfied with results.
Great Product - Worked well
I tested this on several pieces of stainless both polished and satin finished. IT did a good job and looked very even in finish. Used it to touch up a "Black steel" watch band and it worked well for the touch up of shiny wear places.
Great Product, Fast Shipping
Bought the blackener gel kit to restore a Scotty Cameron Putter that had rusted out. It worked great and am very happy with the results.
works great
easy to apply easy to remove no mess
great after "tweaking" the process
I tried several coats on 300 series tubing and the results weren't all that great. So as a last ditch effort I warmed my parts in a toaster oven to approximately 150 degrees F and recoated one last time. Allowed to sit for 5 minutes, rinsed, sealed and they turned out GREAT! I would now absolutely recommend this product and buy it again in the future...
Easy to apply
I used this and it worked well. Easy to work with and easy to control. There was some streaking with it, but I think that's because I laid it on too thick, with more than one coat. I used three coats. Will try one coat on my next project.
