Spiral sewn wheels are the workhorse of most buffing and polishing jobs. Because the plies of cotton cloth are sewn together spirally, the wheel becomes much harder and more pressure can be exerted on it. This is especially useful when 'cutting' the metal.
The faces of these wheels are pre-raked to accept compound immediately.
These wheels are dependable and long wearing.
Use With Any Compound
6" Diameter x 7/8" Thick
7 Reviews Hide Reviews Show Reviews
Great stuff
Does what its supposed to do!
Excellent as Always...Thanks
Polishing
Great for polishing! Use it everyday
Great buff
Have been using these thick buffs with greaseless compounds last few weeks and so far it's been great. What a difference polishing stainless steel, so much faster too. Wheels holding up great.
Excellent
I use these on 300-500 parts per week. With proper raking they hold up quite well to aggressive polishing of narrow parts ( less than .25 wide) that would ruin most wheels. I will definitely be ordering more.
Very durable, high quality.
These are very durable high quality buffing wheels. I put them thru heavy use and I've buffed 100's of items. they continue to retain their shape! Highly Recommend!
buffing wheels
I have used other buffing wheels, and after using Caswell product all other buffing supplies are junk!!!!!!!! I will never use other products. The price of supplies are equal to other companies, why go any place else......
