SPIRAL SEWN COTTON WHEEL 8 X 1/2
Spiral sewn wheels are the workhorse of most buffing and polishing jobs. Because the plies of cotton cloth are sewn together spirally, the wheel becomes much harder and more pressure can be exerted on it. This is especially useful when 'cutting' the metal.
The faces of these wheels are pre-raked to accept compound immediately.
These wheels are dependable and long wearing.
Use With Any Compound
8" Diameter x 1/2" Thick
6 Reviews Hide Reviews Show Reviews
Good quality, does the job.
Very few strands fraying off from these, unlike the kind you buy at big box stores. They hold up well. Be sure to rake every so often and they will last a long time.
No comparison
I originally put on the spiral sewn cotton buffing wheels that came with the bench buffer. Something told me to order two new ones from Caswell and guess what. No comparison. The difference is like night and day. In appearance and performance. Why did I wait so long? That's why they say you don't get something for nothing.
Replcement Wheel
Finally wore out my last Caswell wheel.
ooo
Always excellent. Thank You
Great wheel for cutting
We use these wheels for heavy pit removal steel with wonderful results, these wheels hold abrasive compounds very well, have a short "break-in" time, and the wear rate is exceptional, the cut and load quality is consistent throughout wheel life.
Good cutting wheel
I use these to cut, with tripoli, on antique fans with brass blades. They are usually heavily tarnished and discolored. These wheels eliminate the tarnish easily.
