Spiral sewn wheels are the workhorse of most buffing and polishing jobs. Because the plies of cotton cloth are sewn together spirally, the wheel becomes much harder and more pressure can be exerted on it. This is especially useful when 'cutting' the metal.
The faces of these wheels are pre-raked to accept compound immediately.
These wheels are dependable and long wearing.
Use With Any Compound
4" Diameter x 1/2" Thick
6 Reviews Hide Reviews Show Reviews
Good Stuff
I got 6 of these wheels, and now I want 6 more! These wheels are the good stuff! I use them in my small drill press to buff, and polish small parts, and these 4" wheels are just the ticket. they are well made and holding up very well.
Spiral sewn buffing wheel.
These wheels came pre raked so we're ready to take compound immediately. They worked great and I will be ordering more soon
It gets into the tight areas
These wheels allow for more flexibility in tight areas that my 6" wheels can't reach.
Affordable too!! -
Better than others I've used
These wheels are way better than what came with my buffer. You can tell the difference right away. the faces are "pre-dressed" and ready to accept compound. The cloth they use is a much higher grade than the cheap muslin wheels I've always used. You can tell right away by how soft the face is, and how few strings are thrown. All this quality for the same price other places peddle their crappy ones for. They spin perfectly true, and are well balanced. A++
Great for use with a drill
The 4" spiral sewn wheels were the workhorse wheel I used when buffing a set of aluminum wheels. The 6" wheels are a bit too big for your usual run of the muck drill, but the 4" is perfect. I think going to a 3" would work against you, because of the lack of RPM's that most drills have.
I used two of these, one with black - the other with brown compound. They do an excellent job, and after over a dozen separate uses, my wheels are still usable and have hardly lost any diameter. As long as you keep them clean (rake them!) they will give you lots of service life.
I plan to keep at least a few of these handy for the smaller stuff in the garage, and car parts with crevices that a 8/10/12" wheel can't get into, and a loose cotton wheel would be insufficient.
Highly recommended. -
Will buy again
Great company to deal with. Fast shipping and great prices!
