An excellent metal working grease stick that provides lubrication, reduces friction, tool wear and breakage, prevents burning, welding chatter, galling and tearing. It is particularly good for saw cutting applications. It is compatible with all ferrous and non-ferrous metals. Biodegradable, non-irritating and non-toxic. Uses: Drilling, Grinding, Sawing, Tapping, Cutting, Spinning, Pipe Cutting, Machining, Lubricating Draw Dies, Pulling Wire Through Conduits, Polishing with Coated Abrasives. Packaged in 2-1/2" x 8" Silver Spiral Wound Tube.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
