Sisal is a slender, hard, cellular strand of fiber that has demonstrated its great strength and tough resiliency in the form of binder twine, cord & rope for many years. These qualities, along with its natural abrading and grease absorbing characteristics, provide an ideal buffing wheel fabric. Sisal buffing wheels will provide both polishing and cutting action. They will remove stretcher strains, orange peel, polishing wheel grit lines, light die marks, etc. To effect a fast cut, use a sisal wheel with the Black Emery compound.
5 Reviews Hide Reviews Show Reviews
Excellent service.
Will buy from them again.
would order again
great durable wheel
Excellent for cutting action
I use with black rouge to cut brass and it works excellent
Nice Primary Wheel
Worked well with black compound to clean up castings.
Good quality
Will buy this again
