Sisal is a slender, hard, cellular strand of fiber that has demonstrated its great strength and tough resiliency in the form of binder twine, cord & rope for many years. These qualities, along with its natural abrading and grease absorbing characteristics, provide an ideal buffing wheel fabric. Sisal buffing wheels will provide both polishing and cutting action. They will remove stretcher strains, orange peel, polishing wheel grit lines, light die marks, etc. To effect a fast cut, use a sisal wheel with the Black Emery compound.
5 Reviews Hide Reviews Show Reviews
Great service
Order received as ordered
My favorite supply site great polish stuff
Another Excellent product
Excellent long lasting Sisal Wheels
I always order my wheels from Caswell. Fast shipping and friendly customer service. Best of all, they care the best products! These wheels when used properly last longer than the ebay cheap wheels you get.
Durable, capable of heavy duty work.
When coupled with proper buffing/polishing compound, works excellently at creating a perfectly polished product.
works great
Works great on my stainless. Mine has 3/4 center hole for shaft.
