Aggressive Buffing Wheel For Fast Cutting
With a thickness of 2”, this long lasting wheel is an economic alternative to stacking sisal wheels on a shaft.
The fibers are treated and stiff, giving an excellent hard surface for the initial cut to de-burr etc.
Use with Greaseless compounds or Black Emery.
6" Diameter
i like it
this work well
YOU NEED ONE
This buffer did the trick, I have a mobile crawfish cooker made of stainless steel and it gets alot of use in season. These buffers are durable and make cleaning it a breeze, make sure you have an arbor long enough to mount it.
