Overall Dimensions: 59" (h) x 30 1/2" (w) x 24 1/2" (d)
Working Dimensions: 24" (h) x 30 1/2" (w) x 24" (d)
Side Door: 18" x 12"
Window: 9" x 20"
Construction: 16 gauge steel
Gun Assembly: Trigger operated: 14 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: Not Included
Weight: 110 lbs. (common carrier)
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
