Side Door Opening Blaster
Overall Dimensions: 58" (h) x 36 1/2" (w) x 24 1/2" (d)
Working Dimensions: 24" (h) x 36" (w) x 24" (d)
Side Door: 18" x 12"
Window: 23" x 13"
Construction: Cabinet: Thick wall plastic Legs: Steel
Gun Assembly: Trigger operated: 14 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: Not included
Weight: 75 lbs. (common carrier)
