Overall Dimensions: 60" (h) x 60 1/2" (w) x 35 1/8" (d)
Working Dimensions: 27" (h) x 60" (w) x 35" (d)
Side Doors (2): 28 1/2" x 22 1/2"
Window: 46" x 13"
Construction: 16 gauge steel
Gun Assembly: Foot operated: 20 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: DC1500
Weight: 300 lbs. (common carrier)
