SHAFT ADAPTER R.H. 5/8"
These extenders are perfect for turning old electric motors into powerful buffing machines. Just attach to the shaft of your electric motor, tighten the grub screws and install the buffing wheel.
Use Right Hand Adapters For Right Side Of Buffer (Counter Clockwise Rotation) and Left Hand Adapters For Left Side Of Buffer (Clockwise Rotation)
