Ideal for buffing contoured shapes such as wheels. Scrubber wheels remove rust, scratches, minor blemishes, old paint, and plating. Use a light touch. No compound is required, as the abrasive is already impregnated in the wheel. Gives metal a "satin" appearance. 1/4" Shaft.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
