Ideal for buffing contoured shapes such as wheels. Scrubber wheels remove rust, scratches, minor blemishes, old paint, and plating. Use a light touch. No compound is required, as the abrasive is already impregnated in the wheel. Gives metal a "satin" appearance. 1/4" Shaft.
Nice for corners
Works as designed to clean corners
