SCRUBBER WHEEL 6
Scrubber wheels remove rust, scratches, minor blemishes, old paint, and plating. A featherlite touch is required with these wheels, unlike an ordinary buffing wheel. Heavy pressure will result in premature wear of the wheel. The blisters found in chrome, particularly on pot metal, can be flattened with this wheel. Substrates take a flat satin finish, which should be buffed with emery and a sisal wheel, followed by white or brown compound on a cotton wheel. Fits 1/2”, 5/8” & 3/4" shafts.
My favorite supply site great polish stuff
Another Excellent product
