SAW BLADE WAX STICK
F-168 is specifically formulated for applying to metal cutting saws. The tenacious, clinging grease film left on the cutting tool serves as a heat reducing coolant on the cutting teeth and work surface. The anti-heating properties in the formulation work by keeping the wax on the saw blade or tool, reducing the tendency to spin off the saw blade. The result is a smooth and quick cut, adding longer life to the cutting teeth. F-168 prevents burning, clogging, chatter and tearing. It works well on all cutting operations of non-ferrous or ferrous metals. F-168 is soluble in water, non-toxic, non-irritating and biodegradable. Cleans easily by wiping or hot water flushing. F-168 's fiber tube is made with an extended hollow end "Safety-Grip" hand applicator allowing the operator to hold and push the F-168 wax stick safely against the saw or cutting tool. Uses: Band saws, Circular saws, Carpenter saws, Hack saws. Other uses: Drilling, Tapping, Grinding, Filing, Cutting, Metal Spinning, Polishing with Coated Abrasives. Packaged in a spiral wound Peel-a-Way paper tube 2" x 12" long tube with Safety Grip Handle!
performs as expected
