SANDING DRUM KIT
- Sanding drums are self expanding rubber spindles with hardened metal arbors and nuts.
- Precision manufactured to close tolerance, providing smooth and even performance.
- Use for: sanding, shaping, grinding, finishing, polishing
- Use on: wood, metal, plastic, fiberglass, rubber, glass or stone.
- Use with: portable drill or grinder, drill press, lather, flexible shaft, bench grinder.
- Especially useful for surfaces that are curved or irregularly shaped.
- Max 3000 RPM
Sanding Drum Kit:
Diameter |
Width |
Shank |
1/2" |
1/2" |
1/8" |
3/4" |
1" |
1/4" |
1" |
1" |
1/4" |
1.5" |
1.5" |
1/4" |
2" |
1.5" |
1/4" |
