RUBBER SANDING DRUM
Quick Lock Drums are simple and fast to use. Just turn the rubber cylinder to secure or loosen the sleeve.
*needs wrench to tighten
Great place to do business
The one stop shopping for all your buffing needs and also the tools to dd it. I am also very pleased with the sanding drum.
