This rhodium plating solution is prepared with 100% virgin rhodium obtained from only the highest quality sources. The result is a mirror bright, tarnish-resistant finish that will add shimmering elegance to all your fine jewelry. It does not require special additives and therefore is very easy to use. In addition, nickel plating is not required when rhodium plating over silver for a tarnish-resistant finish.
This rhodium pen plating system comes complete with disposable, battery powered pen plater and 1 oz of rhodium solution. The pen will operate for approx 1 hour of plating time. The pen contains a special platinum anode, that is required for rhodium plating.
Parts must be free of oils, fingerprints etc. and perfectly clean and polished. Soak the tip of the pen plater for approx 60 seconds, then clip the alligator clip to your part, then stroke the tip of the pen over the part where you want plating to occur.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
