TREATED RAZOR BUFF - 4"
1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half inch holes (not pictured above)
