RTV Silicone Mold-making Rubber
- 1 lb Kit Base & Catalyst
- Easy Instructions Included
- Mixing Ratio 10:1/Base:Catalyst
- Working Time: 30 mins
- Cure Time: 4 hours
- Optimum cure is reached in 24 hours. When Alumilite "Quick-Set" RTV Silicone Rubber is fully cured it remains flexible from -70°F to 400°F, with intermittent exposure to 500°F.
- Available in Quick Set and High Strength Formulations
Â
