Professional Gold & Black Krome¨ Brush Plating System
Includes our new Constant Current Control 3 amp power supply.
Unlike competitors ‘pulse platers’, this machine is infinitely variable to allow the user to alter current or voltage to suit a variety of plating techniques and solutions. So, immersion and brush plating can be done with this system.
Fastgold is a 24-carat hardened gold, designed particularly for the aggressive environment that car emblems are subjected to. It is cyanide free and has the advantage of coming in liquid form, which can be gelled using the gelling powder included in the kit.
The nickel substrate found once the chrome stripper is used, does not need to be activated to use Fastgold, saving a step over competitive systems.
The Flash Copper solution is ideal for plating over old pot metal emblems, where pitting or corrosion has eroded the nickel base and exposed the pot metal. After applying Flash Copper to the pot metal, nickel can be applied prior to gold plating.
Copy Chrome may also be applied over a nickel base, to give it that ‘bluer’ chrome appearance.
Black Krome™, applied over a nickel base, will give that ‘smoked chrome’ appearance that is so popular today.
- 1 x 3 amp Constant Current Power Supply 110volt input
- 1 x wand kit comprising:
- 2 x 4 feet connecting wires (red & black)
- 3 Banana plugs (2 red, 1 black)
- 1 alligator clip (black)
- 3 Stainless Brush Plating wands & bandages
- 1 Copper Brush Plating Wand & bandage
- 1 x 4oz 24-carat Fastgold (plates approx 2-3 sq ft)
- 1 x 4oz Gelling Powder
- 1 x 8 oz PNP Nickel Plating solution
- 1 x 8oz PNP Flash Copper Plating solution
- 1 x 8oz PNP Copy Chrome Plating solution
- 1 x 8oz Black Krome™ Plating solution
- 1 x 8oz Chrome Stripper
- Brush Plating Instructions
GHS Info
SDS
a very cool system
it got this to do small parts, but it works so well i have used it for projects i never dreamed it could do. this system is a great value
