PLASTIC BUFFING COMPOUND (FINE)
PLASTIC BUFFING WHEEL BAR COMPOUNDS
FOR USE ON: PLASTIC, HARD RUBBER, CELLULOID. The finest compound for polishing plastic, acrylic, wood and lacquered finishes. Use for the final step.
7 Reviews Hide Reviews Show Reviews
more
more than what I thought it would be, should last me a very long time
These sticks are HUGE!
Appears to be a lifetime supply.
Great final buffing compound!
I use this to finish buffing and this stuff works great!
Works grest!
Used to shine bowls and pens.
Works Great
This compound is great for nitro guitar finishes. Just don't overload the wheel and watch the pressure.
superior finish
used in combination with Plastic Glo and Canton flannel buffs, I have found no more superior finish for acrylic and plastic pens.
superior finish
I utilize the P-112 buffing compound with the Canton flannel buffs to finish all my plastic and acrylic pens. In over 18 years of pen making I have yet to find a more superior finish.
