Multi Purpose Rubber Coating
Coat anything with a flexible rubber coating.
- Flexible - won't crack, chip or become brittle
- Insulates from electrical shock, vibration, heat and deadens sound.
- Provides safe, non-slip comfort and control.
- Durable - resists weather, chemicals, impact and abrasion.
- Can be applied by dipping or brushing
- Available in red, yellow, black, blue and clear.
- 14.5 oz covers approx 5 sq ft at 10 mils.
- Available in 14.5oz and 7.25oz cans.
