Plasti Dip Pearlizer is the latest addition to our Plasti Dip Enhancers line. Like our other Enhancers€”Silver Metallizer, Gold Metallizer, and Glossifier€”it€™s designed to be sprayed on over cured Plasti Dip. Plasti Dip Pearlizer will give any Plasti Dipped surface a unique, pearlescent sheen, as well as a whitish tint. It actually looks kind of like a thin layer of frost, making it perfect for craft projects for the upcoming holiday season. And, of course, it€™s great for untold other applications, as well.
