Plasti Dip Blaze is a unique collection of neon Plasti Dip colors that deliver eye-catching looks for any application. Use Plasti Dip Blaze anywhere you need bright, easy to see colors€”you can use it to improve visibility for safety concerns, to add can€™t-miss color to frequently misplaced items, or for a one-of-a-kind look on almost anything, from automotive projects to outdoor gear to arts and crafts. Plasti Dip Blaze is available in two eye-catching colors, Blaze Blue and Blaze Orange, with more colors in the works for release in the near future. The Blaze collection applies quickly and easily to nearly any substrate material, and creates a protective coating to shield against abrasion, corrosion, mild impact, and the elements. Plasti Dip Blaze also creates a soft, easy-grip surface that helps prevent skidding and slipping. If the coating gets damaged or wears out, or if you decide to change the look of your Plasti Dipped items, cured Plasti Dip Blaze will peel off easily from most surfaces. It leaves the material underneath in its original, pre-Dipped condition. All colors of Plasti Dip Blaze are available in convenient 11-oz. aerosol cans. Just shake it up and spray it on to give any DIY project a vivid, attention-grabbing look. For the brightest possible colors, it€™s best to apply Plasti Dip Blaze over a white base, preferably white Plasti Dip for optimum adhesion.
